info screen on data viewer
c.forester85
Post by c.forester85 »
how do I close the info screen on the data viewer so I can see my data log file
DannyC
Re: info screen on data viewer
Post by DannyC »
I think I just went to "File" and then open the log file you saved.
2017 Camaro SS, Roto-Fab, Soler 95mm ported TB, Flow Tech axle back.
c.forester85
I opened the file and can hit play; it starts I can see the timer running but the info screen stays there
DannyC
Post by DannyC »
Mine opens right up but theres a small window open. I just hit ok and then all I see is the graph.
c.forester85
I have tried 2 more times, I hit file folder; pick log, hit open. The info screen says file open but just want go away. I finished installing a procharger on my truck 5 days ago and can't even drive it. At start fuel pressure is 58-60# after about 3 minutes of running pressure drops to 43#s. Not enough pressure to even drive. Fast Tech told me probably maf or map having wrong signal sent and computer cutting back my fuel pressure. If I could just see this log I can tell them the reading and they would tell me what I have to do to finally get to drive my truck. Very aggravating 5 days.
c.forester85
Thanks for the help. I'm going to see if this tuner can increase my fuel pressue in advanced settings since I can't see the log.
can you post a screenshot of what you are seeing?
c.forester85
I don't know how to copy the page. I can copy other pages on the computer but not from the data viewer. save me I just do not know.thanks
c.forester85
I took a picture.
c.forester85
figured it out. I needed to pick a dashboard. Works fine now. I'm way better with cars than computers. :lamer:
good deal.
