Ok so I am really enjoying this T2! The features are well worth the money.
I have the monitor set up to dispatch 16 different gauges. I can see the display clearly when it tucked into the bottom corner of the windshield. And the accuracy is amazing.
I only ask to know if there is some kind of list of has all the different aspects that can be monitored? It is overwhelming and time consuming to trickle through the gauge editor and select what to monitor and where to put it. Just wondering if there is something that could make it easier to choose what to display and maybe a quick definition of what the gauges do.
Gauges
Re: Gauges
the list is different for each application, so its tough to publish, but I will see if we can come up with something.
Re: Gauges
Does mf cnt# mean Miss Fire Count Clyinder number?
If so, then why wouldn’t a check engine light come on?
Also, would you happen to know symptoms? The spark plugs have been replaced as well as the coils. Wonder if I might have a sticking fuel injector
