Please help
Skull1313
Please help
Post by Skull1313 »
I have a I2 and a 2014 ram. Cannot get the updater to load on my pc. Fails every time. Even the repair after fails. I finally got it to connect with my truck but its as far as it goes. It generates some log then freezes up. I have a t1000 that i used for years. I removed it because the truck was going in for service and updates. I bought the I2 because it was smaller and can mount anywhere. I just want to be able to turn off the MDS permanently and put back in a 93 tune. Thanks.
Re: Please help
so ignition will not install at all?
try uninstalling whatever is there then run it fresh?
And you cant get to the tunes at all?
Never lets you select the tune/
Can you please post the info.xml file from the i2 drive?
Skull1313
Re: Please help
Post by Skull1313 »
<?xml version="1.0"?>
-<tool_info platform="I2">
<registration updates="0" tool_oem="DIABLO_D" status="0" sn="1FSY7KRXO5"/>
-<applications count="5">
<application rev="2t04ja" name="vehicle"/>
<application rev="2r01j" name="updater"/>
<application rev="2r01t" name="gui"/>
<application rev="2r01m" name="installer"/>
<application rev="2r01d" name="logger"/>
</applications>
-<databases gui="2r01i" SAE="3r01h" vin="2r01i" dtc="2r01a" dbnames="2r01b">
<database pid="2r01e" tune="2t02ua" mfr="DCX"/>
<database pid="2t01dt" mfr="FORD"/>
<database pid="2t01ct" mfr="GM"/>
</databases>
-<system rev="1r01a" config="1r01e">
<kernel version="#7 Sat Sep 19 01:29:28 EDT 2015" release="3.17.2-diablo2"/>
<option name="Wifi" enabled="true"/>
</system>
-<last-connected vin="1C6RR7KT7ES374959" mfr="DCX" ecus="2">
<ecu calid="68153791AK"/>
<ecu calid="68234060AB"/>
</last-connected>
<licenses tuned="0" available="1"/>
<reg reg="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"/>
</tool_info>
Re: Please help
the device isnt asking for an update, will it not allow you to tune the truck as it sits?
Its all up to date...
Skull1313
Re: Please help
Post by Skull1313 »
I honestly haven't brought it out and tried it. I thought it needed a update. Plus I couldn't get the updated to load on my PC. I'll go try it this afternoon. Thank you for your help. I'll let ya know.
Skull1313
Re: Please help
Post by Skull1313 »
Well a unexpected error occured. A log was created. Now it just sits there. Please wait. I'm getting tired of it not working.
Skull1313
Re: Please help
Post by Skull1313 »
mikel wrote:the device isnt asking for an update, will it not allow you to tune the truck as it sits?
Will not let me tune anything. :blowup:
Re: Please help
please give us a call so we can get this sorted out for you, 561-908-0040 x4
Skull1313
Re: Please help
Post by Skull1313 »
I was able to get it to pair with the truck. And install a 93 tune. Does anybody know if the I2 supports a separate MDS option or the tune shuts off the MDS? I couldn't find it in the programmer.
Re: Please help
MDS disable is in the modify tune menu in the advanced tune section.
Skull1313
Re: Please help
Post by Skull1313 »
mikel wrote:MDS disable is in the modify tune menu in the advanced tune section.
It's not there. Will only let me adjust tire size and traction control. Advanced tune- tune select or quick adjust neither one allows for MDS option.
Skull1313
Re: Please help
Post by Skull1313 »
Nevermind. I found it!!! Thank you all for your help.
C4rpediem
Re: Please help
Post by C4rpediem »
I got the same problem with my 12 JGC 5.7. Only tire size and traction control.
I can't find how I can change throttle response and disable MDS....
