UPDATES 2014 SILVERADO 5.3
UPDATED MY I3 SEEMS TO NOT HAVE AS MUCH POWER ALSO WONT LET ME CHANGE THE TORQUE MANAGMENT PARAMETER IT FREEZES UP WHEN I CLICK ON IT. IS THERE A ISSUE WITH UPDATES I UPDATED 2 WEEKS AGO AND AFTER A WEEK OF DRIVING IT CAUSED A CHECK ENGINE LIGHT TO COME ON CODE P16F3. ONCE I CLEARED THE CODE AND SET MY STOCK BACK UP TUNE IT WENT AWAY AND NEVER CAME BACK ON.
Re: UPDATES 2014 SILVERADO 5.3
A quick search shows that code to be a known issue on GM trucks and there are bulletins to address it, so it may be something you want to check with the dealer about.
The tunes for these trucks haven't changed since we put them out 6 years ago or so, so the updates wont change the tune itself.
tech@diablosport.com
SO WHY WOULD IT START FREEZING UP WHEN TRYING TO CHANGE THE PARAMETER FOR THE TORQUE MANAGEMENT AFTER UPDATING?
Thats a bug with that specific parameter.
I can turn it off for you in a custom tune if needed.
YES PLEASE I HAVENT HAD A ISSUE WITH IT TELL TODAY AFTER I UPDATED IT.
IM NEW TO THIS HOW DOES A CUSTOM TUNE WORK WHAT DO I NEED TO DO. THANKS FOR YOUR HELP.
post the files from the tunes folder on the i3 drive and I will set it up.
SO ITS BEEN ALMOST A MONTH I DID A FEW UPDATES DROVE MY TRUCK A FEW WEEKS WITH ABSOLUTELY NO TUNE TRUCK RAN FINE NO CHECK ENGINE LIGHTS NOTHING DROVE IT FOR ABOUT 400 MILES LIKE THAT, SO I RETUNED IT DID THE DIABLO TUNE JUST BY ITS SELF DID NOT CHANGE ANY THING ELSE AND WITHIN 100MILES CHECK ENGINE LIGHT CAME ON CODE P16F3 SO I CLEARED IT PUT STOKE TUNE BACK DROVE IT FOR ABOUT 300 MILES STILL NO CHECK ENGINE LIGHT. SO I DID ANOTHER UPDATE TUNED IT STILL JUST THE DIABLO TUNE AND WITHN 200 MILES CHECK ENGINE COMES BACK ON SAME P16F3. I KNOW THAT CODE IS A COMMON PROBLEM WITH GM BUT IT ONLY SEEMS TO TRIGGER WHEN IT HAS THE TUNE. HAS ANYONE EVER HAD THIS CODE COME UP FROM THE PROGRAMER OR HAVE YOU SEEN ANYTHING LIKE THIS. IM NOT SAYING ITS THE PROGRAMER BUT IM AT A STAND STILL CAUSE IVE CHECKED EVERY THING I KNOW TO CHECK ON MY TRUCK.
We'll gladly dig into it if you can post the files from the device.
IM STILL TRYING TO FIGURE OUT HOW TO DO THAT
NOT SURE IF IM DOING THIS RIGHT
Last edited by CraftonMayson85 on Mon Mar 16, 2020 12:44 pm, edited 1 time in total.
thanks, please also post the files in the folder called tunes.
WHEN I CLICKED ON TUNES NOTHING CAME UP IS THERE SOMETHING I HAVE TO DO OR DOWNLOAD TO DO SO
