Modify Parameters on JK
jkblanco1974
I have jk 2009 and connecting the intune i3 does not give me the option to modify the gear ratio, the throttle among others. I have installed the latest upgrade but I don't get those options to modify
Re: Modify Parameters on JK
gear adjust is not needed, the speedo will not be affected by the gear change.
You should indeed have throttle boost, are you going through the whole list?
