2007 Ram 5.7 Hemi P0300
krazray6872
Post by krazray6872 »
I keep having this p0300 code pop up...I have changed coil packs, plugs and camshaft sensor...need help. Does my t2 have fuel pressure gauge? is there any other settings i can use to diagnose problem?
sbenja2008
Re: 2007 Ram 5.7 Hemi P0300
Post by sbenja2008 »
krazray6872 wrote:I keep having this p0300 code pop up...I have changed coil packs, plugs and camshaft sensor...need help. Does my t2 have fuel pressure gauge? is there any other settings i can use to diagnose problem?
I would check for broken valve springs or worn cam and lifters. I don't think the T2 will read fuel pressure on an 07 or at least not on my 07. On a side note does your T2 datalog ok in your 07?
