I installed the 93 octane tune in my 2016 chevy cruze limited 1.4L turbo and I selected to turn off the speed limiter and downloaded the tune and my speed limiter is still engaging at 112mph please help.!
Okay I did the simple tune 93 octane and selected yes for the speed limiter and downloaded the tune and my car's speed limter is still coming on at 112mph. Keeps saying failure to initialize perimeters make sure key is on the run position and engine is not running. It installs the tune but won't turn off speed limiter. I also tried doing to advanced tune and when i go to modify parameters the page is blank
2016 chevy cruze limited LT Rs 1.4L turbo
Speed limiter
Re: Speed limiter
run the Update Agent (Ignition) updater program on you pc/laptop and update that intune to all the latest updates..
Then select/install the tune from the Tune Vehicle - Advanced Mode menu... and choose to Modify the ECM tune when it asks you...
disable the setting.. exit back out, and then install/apply the tune...
