Chrysler 300c 5,7 2006 traction control proplem?
i have intune i2. if i install 91 or 93 tune. then the traction control stops working. mpg tune traction control works. do I need to upgrade Intune i2? updated two years ago.
Re: Chrysler 300c 5,7 2006 traction control proplem?
are you making any adjustments when you install the tun?
has it always been like that?
only cooling fan raised 216
not common to raise cooling fan temps, please return to stock then load the tune with no other changes and let me know if the issue persists.
if so, post the backup and last tune written files from the tunes folder here so I can check them out.
Europa model thermostat 203f.
I downloaded the program without any changes. traction control does not work.
how do i get a packup sent to you?
yes.
ave this file to the root of the i2 drive and let the device import the file then load the custom tune to the pcm and let me know if it still has the issue.
does not work with traction control custom program
are there any trouble codes present in the vehicle with the tune loaded?
malfunction / traction light is off. the traction control light illuminates when slipping and goes out as soon as it stops. scan tool found one code. u0100.
ok, the TC light flashing when the tires are spinning is 100% how its supposed to work.
The tune will allow for more wheelspin. Is that all you are seeing?
if so this is not an issue....
It's winter here. and if you push the gas at 60km / h for example, the car starts spinning at 100km / h
mpg booster tune traction control works normally
