I have an 06 300C SRT8 and a U7135 predator running the latest CROM. My question is about what PIDs are coming through and whether an OBDII gauge (like this: http://www.plxdevices.com/products/dm200obd/ or http://www.aeroforcetech.com/index.html) would be able to read boost from the MAP sensor and/or fuel pressure from the CAN system. Or do I need dedicated gauges with their own senders?
Thanks.
? about PIDs and OBDII Gauge in 06 300C SRT8
1fastsedan
RE: ? about PIDs and OBDII Gauge in 06 300C SRT8
No - those gauges don't have a fuel pressure PID, that needs a pressure sensor and gauge for that. The MAP will read boost but it would be in a value over 100kpa /14.5 psi.
johnc <at> diablosport.com
1fastsedan
OK, so there's no fuel pressure PID. What do you mean about the boost reading? You mean it adds forced induction boost to atmospheric pressure? So if I'm running 5 lbs. of boost, it will read 19.5 psi? If so, that will work for what I need. Thanks!
You are correct. Go for it.
