DSDL keeps "not responding" during update.
Posted: Sat Mar 21, 2020 4:08 pm
by Bensjamming
I got a trinity T1000 and when I try to use it on my 18 Silverado is says it must be updated. So I try to update it and when it's about 1/3 to 2/3 of the way done uploading the crom file it just stops and say not responding. Tried both USB ports and 2 different cables I had around with the same result.
Anyone have a fix for this in DSDL? Would really like to use the tuner I bought but cant get it updated.
Re: DSDL keeps "not responding" during update.
Posted: Sat Mar 21, 2020 4:21 pm
by Bensjamming
Posted: Sat Mar 21, 2020 9:24 pm
you need to purchase an ECM unlock for that 2018 truck...
2017/2018/2019 vehicles require a special unlock sequence... so what will happen is, when you go to install a tune the first time, the tool will give you a message that "one or more controllers can not be tuned - Contacting powertech for vehicle unlock... you will be notified within 1-2 days" - or something similar to that effect.. so then in 1-2 days (usually within an hour though) you should receive an email (if you registered your tool on diablo's site) that your update is ready.. or just run the updater again to update your tool in an hour or so - so then you'd run the Ignition Updater on the tool again, and it will update the tool with the unlock code for your ECM, and then you'd be able to tune the vehicle.
Posted: Sun Mar 22, 2020 12:10 am
by Bensjamming
I got this used so it was already registered before I got it. Is there any way to reset it to be able to register it me?
Posted: Sun Mar 22, 2020 12:12 am
you'll need to contact diablo tech support on Monday...
