Hello.
I have a 2009 Dodge Charger 5.7 and an Intune i3. I Installed the Diablo tune and adjusted a few parameters before installing. After installing, I wanted to go back and make some more adjustments. The only parameters that I see are for transmission, traction control and gear ratio. I would like to adjust rev limiter, throttle and a few other things. Where would I go to adjust these parameters?
Adjusting Parameters after tuning
Re: Adjusting Parameters after tuning
sounds like you're in the quick adjust menu, go through the advanced menu and select modify parameters.
Thanks. I was able to find it. Also, the cold air intake tune, is that the diablo tune if you have a cold air intake?
Yes.
