I have been getting a few engine code faults since I loaded the 91 octane tune. I am getting PO133, PO430, P2096, P2098 codes occasionally coming up. Is there anything I can adjust to eliminate these faults which seem to be lean issues. Also when I did an update the below screen came up;
Any advice would be great.
2010 Challenger RT issues
Mark
Ontario Canada
Ontario Canada
Re: 2010 Challenger RT issues
seem to be pointing to an O2 sensor issue...the tune isn't causing the codes, there is a problem that needs to be addressed ideally.
I am getting a custom tune done first to see if it clears the issue. What about the screen that came up after I did the update?mikel wrote:seem to be pointing to an O2 sensor issue...the tune isn't causing the codes, there is a problem that needs to be addressed ideally.
Mark
Ontario Canada
Ontario Canada
Hi Mike;
I have loaded a Jay Greene tune and all codes are gone. Sounds like it was the mods the car has causing the codes.
Any word on the picture I posted of the update screen.
Mark
Ontario Canada
Ontario Canada
Not sure about that error, does it still do that if you update now?
