2004 codes
Posted: Wed Jun 18, 2008 9:46 pm
by hp325
I have a 6.0 2004. When doing my last udate I showed 2 codes. P0297and P1000. Could any one tell me what set these? :idea:
RE: 2004 codes
Posted: Thu Jun 19, 2008 9:05 am
by sohfast94
The P1000 just means more driving required. As for the 297 did you clear it and drive the truck?
RE: 2004 codes
Posted: Sat Jul 26, 2008 2:09 am
by prostockzuk
I have a 2003 6.0 and I have have a few codes showing also, can someone give me some advice? P0274 cylinder #5 high circuit injector, P1000 says " Test not complete", P2138 and P2140 say the same thing, throttle/pedal position sensor/switch D/E volt. Thank you for your answer in advance.
RE: 2004 codes
Posted: Mon Jul 28, 2008 10:03 am
by sohfast94
P0274 sounds as if you may have an injector coil going bad. 2138/2140 sounds like it the pedal potentiometer may have an issue. Were these codes there before you put the tune in the vehilce?
RE: 2004 codes
Posted: Mon Jul 28, 2008 1:23 pm
by prostockzuk
Thank you sohfast94 for responding as quickly as you did. Your answer for the p0274 sounds right because the truck is starting to run on 7 cyls. As far as the other 2 they just started to pop up and I have had the Diablo for 1 1/2 years. Up until now my truck has run great and right now I just want to find the problems and fix them without it costing me too much money. Thanks again.
RE: 2004 codes
Posted: Mon Jul 28, 2008 1:29 pm
by prostockzuk
Sohfast I have another question. Is it hard to change the injector coil and can I just go to Ford and purchase 1 and put it on? I am a professional motorcycle builder and I don't know how detailed the job is. Thanks again.
RE: 2004 codes
Posted: Mon Jul 28, 2008 1:41 pm
by sohfast94
The injectors are under the valve covers. It's not all that intense but definitely a pita. If you have mechanical ability and a manual I'm sure you could figure it just be careful Diesels run at insanely high pressures....
