i3 Tune - now ABS, ESP/BAS, Brake light on
Finally got the MDS shut off on my 2006 Dodge Durango Limited 5.7... Modified my tire size and put the truck on the road and about 2 minutes later the ABS, ESP/BAS, Brake, and the Anti-skid lights all come on and stay on... It doesn't affect driving or braking and apparently it's a result of the tune... I understand after reading a few older posts that this had occurred on a few occasions with the i3 tuner and the culprit was the tire size tune... Anyone have a solution to this I would greatly appreciate it...
Re: i3 Tune - now ABS, ESP/BAS, Brake light on
do they go away after returning to stock?
Not returning it to stock, no... Seems that when I was finally able to do so, I reverted back to the stock tire settings and then used a high end scanner to go in and reset the ABS and clear all the codes (P1078 and U0100)... This finally worked as the lights have yet to come back on and the MDS has been shut off... The problem that I have now is that the wifi configuration will not recognize my network... All the other devices I have can connect immediately though... It's an I3 - Platinum 8245... I would like to get a 2nd license for my Charger Daytona, but without wifi ability it would not be feasible since I'll be on the road a lot and not near home... Any ideas?
