Need help with Predator tuner and nitrous!
Posted: Fri Jun 27, 2008 7:22 am
Post subject: Using the diablo with Nitrous PostPosted: May 31, 2007 - 02:19 AM
Is it possible to use the diablo sport tuner on a mustang utilizing a zex nitrous system.
i understand that using the diablo will increase ignition timing a cause detonation.
am i able to use the sport tuner for other apllications like rpm limit and gear ratio etc without having to curb the ignition timing and other things that will cause detonation.
in other words, are the options individually selectable
View user's profile Send private message
Reply with quote Back to top
Post subject: RE: Using the diablo with Nitrous PostPosted: May 31, 2007 - 02:46 AM
You can either tune from stock and make only changes you would like, or use the provided performance tune and retard the timing from there.
_________________
Diablosport inc.
mlitsch @ diablosport.com
Please do not PM us for tech support, post up first!!!
cliffymorris
Post subject: RE: Using the diablo with Nitrous PostPosted: May 31, 2007 - 05:58 AM
thanks
so you can retard the timing for things like nitrous instead of advance spark, and also can you only have it retard wen the nos is activated, because, obviously, i would loose horse power due to retarded timing wen driving under normal conditions...
thank you
Post subject: RE: Using the diablo with Nitrous PostPosted: May 31, 2007 - 06:35 PM
There is no way to have it only retard when activated, so you'll want to retune when not using the N20.
_________________
Diablosport inc.
HECTOR
Post subject: RE: Using the diablo with Nitrous PostPosted: Jun 27, 2008 - 03:14 PM
Hey! A question on this one... Can the tuner be used in conjunction with a diablosport delta chip!? Does that make any sense!? I already have the chip and Im getting nitrous, so I decided to order the tuner with hopes of retarding the timing, Plus I have other upgrades and Im sick of the engine light going off because of exhaust and O2 sensors!
I have a 98 Mustang GT, These are my upgrades:
70mm Throttle Body 80mm Cold Air Induction Kit Mass Airflow Sensor Underdrive Pulley Kit 24lb Fuel Injectors MSD EDIS Coil Pack DiabloSport DeltaChip "Performance DiabloSport MAF i.a. Venom 400 Control Module BBK 1-5/8â€
_________________
Diablosport inc.
cliffymorris
thanks
thank you
_________________
Diablosport inc.
HECTOR
