Just an item for the wish-list:
If possible, could the Cooling Fan parameters be added to the Quick Adjust menu? That would be especially beneficial for those of us running cooler thermostats.
It is a fairly common practice for us cooler T-Stat guys to bump up the Fan temps every couple of weeks so we can get the oil temp over 212 -- just to flash off water and contaminants.
Also regarding the Fan settings....I found when I set the temps for the Fans to come on, install the changes, and go back to check the Fan temps again -- they are 2 degrees less than what I set. If I set for low speed to come on at 185^, I go back to check and the low speed is set to come on at 183^. This is with all the Fan settings -- both AC on and off. Any ideas why this would happen?
Thanks,
Phil C.
Add Fan Settings to Quick Adjust menu
07 300C: Predator / 170 TStat / Flowmaster Super 40's / AFE Stage II / BT Catch Can
13 Jeep Wrangler JK: inTune DCX / AFE Pro-Dry drop-in
RE: Add Fan Settings to Quick Adjust menu
Quick adjust items are things that can be changed without a full flash. I'm fairly certain the fan code is deep inside the programming and does require a flash to change.
Re: RE: Add Fan Settings to Quick Adjust menu
Correct...Mike_Levy wrote:Quick adjust items are things that can be changed without a full flash. I'm fairly certain the fan code is deep inside the programming and does require a flash to change.
The fan settings change like that due to the factor used to convert the hexadecimal value to a numeric value.
The predator sets it to what you set it too, then the factor might round the value up or down, it should not vary more than +/- 2 degrees when you look at the adjusted value again. Just one of those quirky dcx things.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
