2012 Ram 1500 Sport 6 spd
powgenman
Post by powgenman »
Do all 6 speeds take a tune?
If not is there a way to tell if mine dose?
TCM doesn't show up just PCM. When I load a tune it changes the way it shifts.
I am not happy with the way it shifts with the tune. upshifts to quickly.
Re: 2012 Ram 1500 Sport 6 spd
6 speeds dont use a tcm, its all in the pcm, trans control is there.
powgenman
Post by powgenman »
Did update, been a while. took a bit of time, lots of updates. Connected to the truck i3 said calibration update needed so :-? reconnected to pc. downloaded update and reconnected to truck. now gives access to trans shift points 8) I can now control shift points at different throttle percentages. the only adjustment I don't see is torque management :(
Should there be adjustment for this now? :?
powgenman
Post by powgenman »
powgenman wrote:Did update, been a while. took a bit of time, lots of updates. Connected to the truck i3 said calibration update needed so :-? reconnected to pc. downloaded update and reconnected to truck. now gives access to trans shift points 8) I can now control shift points at different throttle percentages. the only adjustment I don't see is torque management :(
"BUMP"
there is no TM param for the Rams, TM is already disabled or reduced in the tunes.
