Update i3 is failed
Boiler
Update i3 is failed
Post by Boiler »
Hello!
I haven't update my i3 for a while and tried to update today. In the middle of downloading the update i've got a message - device error, not enough room on device for update file /DCX_TUNES.itf
There is info.xml in attach
Re: Update i3 is failed
try this
open the folder called runtime and delete all the files in that folder, then launch UA and let it try the update again.
LMK.
Boiler
Post by Boiler »
Hi Mike!
Nope, it doesn't work. It failed on 10/12 update :(
OK, that seems to work for me usually.
Do you have a bunch of saved logs in the logs folder?
If the device is working fine you'll be ok, they are working on a fix for this.
Boiler
Post by Boiler »
it works fine for me. totally forgot about heavy logs.
after deleting them, the tuner had updated.
thanks a lot!
