Good day DiabloSport team,
I hope you’re in good health.
I have a 2019 Dodge Charger Scat Pack and recently I bought PCM and Trinity device from your website. I did the installation by following the instructions for installing the PCM but the car won’t start and the security light is on.
I re-installed the OEM PCM and everything is ok. So could you please advise what is the issue?
Thank you,,
2019 Charger Scat Pack Engine won’t start after install PCM
2019 Dodge Charger Scat Pack:
- AFE Momentum GT Cold Air Intake System.
- Hellcat Dynamic Air Scoop.
- JBA 1 3/4" Stainless Longtube Headers.
- Mishimoto Thermostat.
- Billet Technology Oil Catch Can.
Re: 2019 Charger Scat Pack Engine won’t start after install
theres a few threads discussing this, and there are instructions in the box with the pcm that explain the process of reading data from the stock pcm that has to be loaded t the new pcm before it will run the car.
On a JL or any 19+ model dodge/jeep/ram, a replacement/modified pcm will not work until you have followed the instructions on the paper in the box with the pcm.
Thanks Mikel.
Mistakenly I threw that paper. Kindly attached here.
Thank you.
Thank you.
mikel wrote:theres a few threads discussing this, and there are instructions in the box with the pcm that explain the process of reading data from the stock pcm that has to be loaded t the new pcm before it will run the car.
Hello,
If you mean that paper. Yes, I followed.
Got it from Youtube but I’m not sure if that instructions works for 19 also.
Thanks,
Thanks,
Hello,
I would like to update you I followed this topic https://forum.diablosport.com/viewtopic ... 69&t=77842
nd everything is working fine now.
Thanks a lot!
Thanks a lot!
glad to hear it.
I'll check on the papers not being in the box.
