Unexpected error
PJB4x4
Unexpected error
Post by PJB4x4 »
When trying to adjust parameters on my 2011 Sierra I get this error message. It doesn't go away after doing the error log thing.
I can read and clear DTC's just fine and have been able to change parameters in the past (I've had this tuner for almost 100k miles).
What is the issue?
Paul
2011 GMC Sierra Z71
5.3 v8
Re: Unexpected error
is it a specific parameter, or any parameter?
PJB4x4
Post by PJB4x4 »
mikel wrote:is it a specific parameter, or any parameter?
Just getting into the adjusting section it gives the error. Can't even adjust anything like I used to be able to
Paul
2011 GMC Sierra Z71
5.3 v8
can you please post the current info.xml file from the i2 drive so we can check this out?
PJB4x4
Post by PJB4x4 »
mikel wrote:can you please post the current info.xml file from the i2 drive so we can check this out?
how do I do that? I can't remember exactly how
Paul
2011 GMC Sierra Z71
5.3 v8
just realized we are in the i1000 section, is this an older i1000?
the file is on the drive called intune when connected to a pc.
PJB4x4
Post by PJB4x4 »
I bought it around 2012.
I can try connecting it later, need to find the box with the cable
Paul
2011 GMC Sierra Z71
5.3 v8
PJB4x4
Post by PJB4x4 »
2015, I was wrong with the year.
I get these errors when plugged into my computer.
Paul
2011 GMC Sierra Z71
5.3 v8
PJB4x4
Post by PJB4x4 »
<?xml version="1.0"?>
-<tool_info>
<main svn="7842" sw_rev="1r04d" full_version="InTune-1r04d 08/15/2014 12:04:06 PM"/>
<registration status="1" sn="K916WB3-7"/>
<cal_id CM2="20791915, 20823356, 20808547" CM1="24256125, 24258793, 24258799, 24257358" PCM="12639835, 12637644, 12640535, 12625892, 12620683, 12636563, 12631612, 12639957"/>
<restore bc="6" vin="1GTR2VE39BZ406133" id="0"/>
<system_db vin="1r01e" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01e" mfr="DCX"/>
<db pid="1r01b" tune="missing" mfr="FORD"/>
<db pid="1r01a" tune="missing" mfr="GM"/>
-<license tuned="1" avail="1">
<tuned vin="1GTR2VE39BZ406133"/>
</license>
<updates count="3"/>
<oem tool_oem="DIABLO"/>
<reg reg="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"/>
</tool_info>
Paul
2011 GMC Sierra Z71
5.3 v8
device needs to be updated.
PJB4x4
Post by PJB4x4 »
mikel wrote:device needs to be updated.
how do I do that? I'm pretty sure I never had to do it before.
It comes up with error when checking for updates and closes the intune program on my desktop computer
Paul
2011 GMC Sierra Z71
5.3 v8
sorry, its a bug we re working on currently.
PJB4x4
Post by PJB4x4 »
mikel wrote:sorry, its a bug we re working on currently.
ok so my device isn't junk in that case?
Paul
2011 GMC Sierra Z71
5.3 v8
its fixed, should be able to update now.
PJB4x4
Post by PJB4x4 »
mikel wrote:its fixed, should be able to update now.
I just tried, same errors
Paul
2011 GMC Sierra Z71
5.3 v8
