Hi All,
We have a mustang AWD MD-500 dyno that is giving us a headach.
When we do a pull on a car it will not show the full pull on the graph. The correct RPM is shown on the screen but the rpm is cuts off earlier on the print out so therefore the numbers are not accurate. I do have it set to 6000RPM even though you cant see it in the pic.
Tried default setting and making adjustments but nothing seems to work. Called Mustang and they are out of ideas Any in put?
Thank you
Mustang Dyno Issue?
AMP_Tuning
Mustang Dyno Issue?
- MDissue.jpg (3.99 MiB) Viewed 2413 times
Re: Mustang Dyno Issue?
Really not sure. We dont use an MD here, we have a pair of SuperFlows and a DJ.
I'll see if one of the calibrators has some MD experience to share.
