WiFi Setup not working?
Whenever I attempt to check for updates, while powering the i3 thru USB connected to my computer, I get the "Terms Screen", I hit Yes, Settings, Advanced Options, Check For Updates....I get the Unit can be updated by WiFi screen, hit continue, Terms, yes, Settings, WiFi Configuration, Connection Info... It is Blank? I go to WiFi Setup...device Freezes? How can this be fixed?
Re: WiFi Setup not working?
Used Update Agent while connected to computer...downloaded update fixed the WiFi display...Thanks!!
Mike, Just wanted to let you know the wifi isn't working on my i3 still. After the PID issue got fixed it still freezes up on the Wifi setup screen when I click on it. Last update for me was the R300 r33. Sorry to be a thorn in your side. Honestly though, not a big issue as I do 99% of my updates on my laptop. Just wanted you to be aware that the issue is still out there. Thanks.
please update and it will be fixed.
mikel wrote:please update and it will be fixed.
That did it. Thanks
