2013 Ram 2500 with 6 speed tranny.
I have the i3 for Dodge locked(Cannot use custom tunes).
What I am looking for are settings for more torque with less REV and less shifting at highway speeds. Is there a difference in the shifting points and throttle percentages in the different tunes ? I'm running the 87 tune and towing tune. Will a different tune give me what I am looking for? The only thing I have changed is I have set 1st to second gear shifting a little higher RPM as I use the truck for plowing in winter and prefer to have the engine rev a little higher in first before shifting to second while pushing the snow.
Out on the highway though, I would prefer to be able to keep the revs lower and use the the engine torque to push thru, instead of having the tranny continually shift all the time.
6 speed tranny.
Thank you in advance. Love the forums. Havent been here in a while. Merry Xmas 2020 to all !
2013 Ram 2500 5.7 6 speed Hemi tune for torque
mbrobich1966
Re: 2013 Ram 2500 5.7 6 speed Hemi tune for torque
You cant change cruise rpm without changing the rear gearing to a taller ratio.
