New unlocked PCM
Posted: Mon Jun 21, 2021 4:32 pm
by UARPerformance
Hey Guys. 2020 Challenger new modded PCM. Is it plug and play or does it need to be programmed also
Re: New unlocked PCM
Posted: Tue Jun 22, 2021 10:21 am
any 18+ pcm replacement requires that you read the skim from the stock/original pcm first then load that to the replacement pcm before it will function in the vehicle properly.
Posted: Tue Jun 22, 2021 4:26 pm
by UARPerformance
So if tech installed installed without previously doing that and then follows the procedures. should it function then? I put the old PCM back in read the old one. Then installed new one wrote tune to it. Now no crank issue. Has skim code
Posted: Wed Jun 23, 2021 10:11 am
by UARPerformance
Hey Mike tried it again by putting the old PCM in the vehicle and then reading it and then reinstalling New Modded PCM in it. Installing Diablo canned tune and once again Skim code. \Called Chrysler to get Pin # so I could do it through J1234 tool, BUT since I don't have a Chrysler invoice for it. They will not give it to us. Guess they are starting to get a bit tight on giving them out. Whats next?
Posted: Thu Jun 24, 2021 11:04 am
something is missing, give the support team a call and they'll get it sorted out.
Posted: Mon Jun 28, 2021 2:25 pm
by UARPerformance
Thanks Mike! They got it handled
