Tuning on top of custom tune?
Posted: Mon Jun 28, 2021 1:24 pm
by Docholiday17
Hi, so I'm planning on throwing a cam in my Challenger this coming year, with a custom tune installed on the Trinity for it.
So I'm assuming it's going to have a pretty lopey idle.
My question is, can I adjust the custom tune and raise the idle speed a bit to smooth out the cam at idle? If I can, am I then able to save that as a separate tune so I can switch between the slightly higher idle tune and the "original" one quickly?
Re: Tuning on top of custom tune?
Posted: Thu Jul 01, 2021 12:09 pm
No, you will absolutely need a new custom tune for any cam swap.
Posted: Sun Jul 04, 2021 11:31 am
by Docholiday17
No, I know that, but I mean after I get my custom tune, can I just up the idle a bit, on top of that custom tune? And then can I save that increased idle tune as a separate one?
Posted: Tue Jul 06, 2021 12:02 am
by doc440
Docholiday17 wrote: Sun Jul 04, 2021 11:31 am
Yes, I have modified versions of custom tunes loaded as new custom tunes. When you modify the custom tune by raising the idle or messing with throttle boost, those changes will be saved in the “Last Tune Written” file you’ll see when connected to a computer. Right click on the last tune written and copy it, paste onto the desktop, then right click the copied file and re-name it. Then drag and drop the re-named file back into root directory of the device like you would any custom tune. It should then show up as a custom tune in the custom tunes menu.
