Corvette Shift settings
Anyone know the difference between shift pressure normal and shift pressure sport/tow. I changed pressure on 2012 Corvette with A6, sport mode and D mode act the same way. Paddle shifters act same way, what is difference?
Re: Corvette Shift settings
the tcm uses separate pressure tables depending which mode you are in.
tech@diablosport.com
I changed pressure setting in sport mode only, but D mode pressure settings also changed
