READING FUEL PRESSURE
Is there a PID for reading the fuel pressure at the fuel rails ? Thanks.
Gʀᴀʙʙᴇʀ Bʟᴜᴇ 2017 Mᴜsᴛᴀɴɢ GT 300A
Re: READING FUEL PRESSURE
I am not sure if thats on the tool or not. I'll check, but it would probably be listed as FRP or similar.
tech@diablosport.com
The only thing I found under 'advance' was FPDC ( fuel pump duty cycle ). But it show weird numbers like from 1000 to 26747. No idea what that means. Tried changing it from 0-100% but it always reverts back to those odd numbers.
do you have a copy of the log with the FPDC data?
OK, I found one of the logs and the data is odd, let me see whats up with that.
Here is another log incase you need it.
They are currently looking into that pid not displaying properly.
