Second Logged run w/ requested data points
Posted: Thu Jul 03, 2008 11:38 pm
by angrygnat
Was gone to the UK for a bit, finally got around to logging a new run with the parameters that you guys asked for. 7.5* max ST KR. 2nd gear, 2K RPM to shift.
Log attached. What do you guys think, where to start?
RE: Second Logged run w/ requested data points
Posted: Thu Jul 03, 2008 11:39 pm
by angrygnat
I couldn't figure out how to shut the loggin off so it ran until out of memory.... hints??
Posted: Fri Jul 04, 2008 3:09 am
by Quick
Try the <back> or <esc> key. The one in the upper left corner relative to the 4 arrow keys.
Re: RE: Second Logged run w/ requested data points
Posted: Fri Jul 04, 2008 10:46 am
by angrygnat
Quick wrote:Try the <back> or <esc> key. The one in the upper left corner relative to the 4 arrow keys.
Tried them, no workie.
RE: Re: RE: Second Logged run w/ requested data points
Posted: Fri Jul 04, 2008 8:49 pm
by Quick
Hmmm, When mine (U-7135 with 9r04) is logging and I press the <Back> button it goes back to the menu with "watch and record" and "Playback" on it. Hopefully someone else can help.
Re: RE: Re: RE: Second Logged run w/ requested data points
Posted: Sun Jul 06, 2008 10:48 pm
by angrygnat
Quick wrote:Hmmm, When mine (U-7135 with 9r04) is logging and I press the <Back> button it goes back to the menu with "watch and record" and "Playback" on it. Hopefully someone else can help.
That's exactly what I thought I did last time but didn't work this time... maybe a fluke??
Posted: Mon Jul 07, 2008 5:39 am
by Quick
No idea. I have not heard of anyone having that problem. Maybe a bad/sticky button on the unit? Does the <back> button work fine for everything else? It would be a pain but you might try reflashing the handheld. Make sure you have any custom tunes saved on your PC. Then restore original backup to the car which will also reset the handheld (unmarry from the car). Then update the CROM on the handheld and start over.
Posted: Mon Jul 07, 2008 11:58 am
by angrygnat
Quick wrote:That's exactly what I thought I did last time but didn't work this time... maybe a fluke??
Ran it again and it worked fine with the esc/back... must have been a fluke hang up?
Now, how about that log? You look at it yet?
