Hello all,
I very recently did the dod delete, and when i tuned the with I3 i used the diablo tune with firm shift. does this tune not get rid of the afm. I just noticed it goes into v4 when i slow down.
I did see this post with this tune which i attached.
is this tune going to work on my 2018??
2018 silverado 5.3
Re: 2018 silverado 5.3
you need to choose to Modify the ECM tune when it asks you, and go to the AFM/DOD setting and disable it... then exit back out and install/apply the tune...
Ok I did the dod turn off. Now I got a map sensor cel what is going on
whats the actual code?
tech@diablosport.com
