New Trinity T2 tuner questions
Jedimeister
Post by Jedimeister »
Just got a Trinity T2 for my wife's 2006 Magnum RT. It came with some canned tunes, but the "Diablo" tune doesn't specify what octane gas to use. Is it only for 91+ octane, or can you use 89?
Also, I pulled up the gauges and customized some of them, but for some reason the "gear selection" doesn't change from "Park" and the "Oil Pressure" is only registering 2-3 when the built in info center displays 15+ PSI. If I had to guess on the Oil Pressure issue, I would say that it's showing me some sort of sending unit voltage instead of actual pressure.
Re: New Trinity T2 tuner questions
Diablo Tune is normally for 93 octane... there would be a separate 91 Octane tune for 91 octane gas.. if there is no separate 91 Octane tune, then the Diablo Tune would be for 91/93 octane...
If you have the V8 engine in that car, you should not be using 87/89 octane gas in it anyway... You need to use at least 91 octane gas in it....
aleksdafreak
Post by aleksdafreak »
2015 chevy silverado 5.3L L83. I have the T2 EX. It only has canned tunes for 87 Oct, milage booster, and modify stock and custom tune. Does it not have a diablo performance tune for CAI?
