I3 data log fails to record
- Legit_Poseidon
i have a 09 silverado 1500 5.3 4x4 flex fuel took the tune fine but every time i try to data log i turn the key to run hit data log and wait till the record option comes up then select record and wait like instructed but it always fails and says a runtime log has been made. I made sure its up to date as of today any ideas or am i just doing it wrong
Re: I3 data log fails to record
try choosing the restore default PID option and see if that resolves it.
tech@diablosport.com
- Legit_Poseidon
No dice tried that and it took a little longer to give me the failed message
start the truck up first... have it running... then go into the data logging...
- Legit_Poseidon
Started it up loaded my i3 to the data log hit record after about 5-8 minutes still a failed to record and a drive log created
have you updated it to all the latest updates/fixes using the new Update Agent program installed on your Windows pc/laptop??? (do not update it using wifi)
- Legit_Poseidon
Yeah update agent says I’m up to date with 1.75.421.56179
Yeah, that's the latest version of the Update Agent program itself...
So close that... connect your inTune to your pc/laptop and get it to the main menu/screen...
Then run/launch the Update Agent program and update your inTune to all of the latest updates/fixes...
- Legit_Poseidon
Ok plugged in updated got the current update screen went out turned key to run hit scan tool then data log let it load got to the record option started truck hit record waited about 5 minutes for it to load still getting the failed message and created a runtime file
can you post the 9 digit serial number off the device?
any aftermarket electronics or OBDII stuff wired into the vehicle?
- Legit_Poseidon
Yeah it’s 201950772 and nothing wired in other than a aftermarket head unit
- Legit_Poseidon
Anyone have anymore ideas ? Starting to think I need to just sell this thing and get a hp tuner
Glad I just saw this again. I think I found it. Do you have a replacement fuel pump module or something in the vehicle?
I have seen these dorman cals cause problems like this in the past:
<ecu calid="DORMANPRODUCTS, E1F80001FSCM, 601022Ver3"/>
Thats from your info file.
- Legit_Poseidon
I had the fuel pump module replaced awhile back I can see if it’s a dorman is there anyway to datalog with it or would I need to replace it with a delco?
I dont think its anything you need to address, more so something we need to look into or sort out.
