A little help<
Posted: Tue Jul 15, 2008 10:44 pm
by josepht85
Hey guys, i know this is for predator tuner question, but since we all in here are familiar with chevy's i have a question. I'm never had a chevy, always a ford until i got my 06 z71. But i have a problem know and i can't find it and some of you might have had it. I have a 4 inch lift and 35's on the truck. When i go over a bump at slow speeds i get a bump out of the rear end like the axles have alot of slack and are bumping the pin in the carrier. The truck has only 40,000 miles on it so the axle bearing shouldn't be worn. Has anyone ever heard this bump. If so did you fix it. Thanks
RE: A little help<
Posted: Thu Jul 17, 2008 9:50 am
you'd be better off posting this in a truck forum...
Re: RE: A little help<
Posted: Thu Jul 17, 2008 12:25 pm
by CANUCKPREDATOR
06MonteSS wrote:you'd be better off posting this in a truck forum...
http://www.gm-trucks.com
RE: Re: RE: A little help<
Posted: Fri Jul 18, 2008 2:04 pm
by ches111
You need to visually inspect your rear end (yeah I said it that way on purpose :)) and see if there is any noticeable areas which could be hitting. Are you hitting the bump stops?
