Does anyone data log with a predator 2? Can you adjust injector slope like the legacy models did off that excel program?....just had to put your logging numbers in and it spit out what the injectors should be set at. I remember doing it for my 03 4.8L and I was really happy with how it turned out. Appreciate any help.
2015 GMC Sierra 2500HD
6.0L gas
Data logging
Re: Data logging
No, P2 does not offer that option. i3 and t2 platinums offer the injector slope and WOT fuel options.
tech@diablosport.com
Re: Data logging
No... not on that newer 2015 truck...
Re: Data logging
He has a 6.0, that thing stayed port injection to the end.
Re: Data logging
Right I know, I've tuned a TON of them... but he can't get the data from a log with that predator 2 tool he has or make adjustments with it - and he shouldn't anyway - and he can't use that old DSLogRedux program that I and Frank created... So no, he can't do it for that 2015 truck he has... which is what I said...
SG2550 -- You'd need to get an inTune i3 8245 Platinum version tool instead, and then I could do a custom tune for the truck and get everything adjusted and dialed in correctly, via MAF sensor scaling instead of changing injector flow rate from stock, as well as much much more that I do with my custom tuning...
You can email me directly at: diablo DOT help AT gmail DOT com
Thanks!
-Lew
Re: Data logging
Appreciate the help gents. Yea I think I will just run the preloaded tunes for now on the P2, I was just looking for better drivability anyways. But if I could do the slope I was going to because it was a significant difference on my old 4.8LS..no worries. Happy holidays to you all
