Can't download revision.
Snort
Post by Snort »
I noticed that there was a revision for my U7155. I downloaded the revision and the downloader to my computer. When I try to put it in to the Predator I keep getting a"Application is missing or corrupt" message after some of the packets are transferred. I followed the steps to try to uncorrupt the tuner but I am not sure if I have succeeded or not. Should it give a message if it has been repaired?
Any suggestions?
johnc
RE: Can
Post by johnc »
Check the size of the CROM file that you downloaded - right click on the file, select Properties. Compare that to the size of the file listed on the Support page for 7155. I am guessing that you do not have the entire file. Sending the CROM file to the Predator should take a while.
johnc <at> diablosport.com
Snort
Post by Snort »
The file size on my desktop is 735 KB while the file size on the download page is 753 KB. I have tried to save the file several times and this is what I always get. Also tried to put the original revision back in to the truck and it would not work either.
Are you downloading from a wireless connection?
Snort
Post by Snort »
Yes I am. I do not have access to a land line connection.
I'll try emailing it to you...
Snort
Post by Snort »
Thanks Mike but I still can't load the file that you e-mailed either.
May need to try a different PC?
Snort
Post by Snort »
I tried the original on two different PCs but I will try this one on a second PC as well.
Snort
Post by Snort »
I have tried to download the version that you e-mailed from a different PC but I am having the same problem.
This is odd...we have hundreds of people download these files every week, check your firewall connections?
Snort
Post by Snort »
I disabled all of my virus protection before trying. I am not sure that I am getting the Predator uncorrupted before downloading. Could you give me better instructions than the help?
Can you call so we can walk you through it?
Snort
Post by Snort »
I have tried using a different serial cable like Vas suggested but nothing has changed.
Snort
Post by Snort »
Ay other suggestions?
Return to “Predator Ford Gas”
