Predator p2 handheld
I have a handheld p2 for a 2011 ram truck with 5.7 hemi can I use the same handheld to tune my car it's a 2013 dodge charger with 5.7 hemi can I just download like a file to be able to use it on my car dont want to have to spend another 400 on another tuner when I alrdy have the p2 handheld the number on the back are x00011200201707716 if this help any info would be great
Re: Predator p2 handheld
you can return the stock tune to the Ram, then use the P2 on the Charger.
Sadly I no longer have the truck forgot I even had this handheld sadly it's still married how do I go about unlocking it are yu sure it will work with my car
Iap:23
Sku:7302
Sn:201707716
Thts the number on screen when plugged into computer if this helps I dont want to pay for unlock unless it will forsure work on my car thanks so much for your help
Sku:7302
Sn:201707716
Yes it will work once unlocked.
So I will be able to change it from 7302 to 7301 an tune an disable mds on the charger how will I go about getting the ram tune files changed to charger files will I need to call diablosport support thanks so much for your help
it should just work, no need to do anything.
