Fan temp adjust
sicksphoota
Fan temp adjust
I have a 2006 Msrt8 can you explain how to make my fans turn on sooner maybe 180° dont seem a option for that on my T2 platinum
Re: Fan temp adjust
set all the fan temps 20* lower than they are by default then save and install the tune.
bobradley4
Re: Fan temp adjust
Same question, different vehicle. Can the trinity 2 platinum adjust fan temp? no matter what I adjust it to in the tune it doesnt come on until around 204
2018 ram 1500
2018 ram 1500
Re: Fan temp adjust
few thoughts...bobradley4 wrote: Thu Aug 01, 2024 6:07 pm Same question, different vehicle. Can the trinity 2 platinum adjust fan temp? no matter what I adjust it to in the tune it doesnt come on until around 204
2018 ram 1500
newer vehicles are different, you have a 'target ECT' parameter on the newer models where you ask for a target temp and the pcm controls the fan logic to get it there.
At idle or low vehicle speed, the fan logic is completely controlled by the pcm, meaning your changes don't take effect until the vehicle is moving (5 MPH+ usually). Since the pcm knows there is no airflow through the radiator at idle, it does what it feels it needs for the fans to hold temp.
bobradley4
Re: Fan temp adjust
So if I want my fan to cut on at 192 I will need a custom tune?
Re: Fan temp adjust
no...i think we're not on the same page.
The fan control you have is pretty much all there is, not much a custom tune will do beyond setting the commanded ECT value to 192 in the tuner.
duuplo2003
Re: Fan temp adjust
Same issue here: 20116 Ram 1500 5.7L 4WD.mikel wrote: Fri Aug 02, 2024 11:08 amfew thoughts...bobradley4 wrote: Thu Aug 01, 2024 6:07 pm Same question, different vehicle. Can the trinity 2 platinum adjust fan temp? no matter what I adjust it to in the tune it doesnt come on until around 204
2018 ram 1500
Thanks for clarifying about target temp vs max temp. I thought I was setting max temp at 195* and couldn’t understand why the fan doesn’t kick on until 205*. It cools ECTs to about 192* and then cuts off.
Another question: the 87 and 91 octane tunes are self explanatory, but what octanes can you use for the Diablo tune and Jammer CAI tune? And can you run any CAI with the Jammer CAI tune?
Thanks in advance.
2016 Ram 1500 Bighorn 5.7L 4WD CCSB
- Intake: S&B cold air intake, 6.4 manifold.
- Exhaust: AFe shorty headers, Flowmaster 50 HD muffler.
- Ignition: MSD Blaster coils, NGK Iridium plugs.
- Cooling: 180* t-stat, V6 efan, clutch fan delete, AGS delete.
