WHEN GUYS.......WHEN?
08stonedcharger
Post by 08stonedcharger »
I have a 2008 Charger that wont shift from 2-3, this is a problem that Diablo Sport has known about for a long time now! Are you guys working on a fix? How much longer? Why so long? HELP US 08 Guys already!!!!!!
johan
RE: WHEN GUYS.......WHEN?
Post by johan »
If you are talking about the raised shift points it will be awhile, we need to add tcm support to that in order for the raised shift points to work. The ETA on that is not known at this point.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
ZMagnum
Post by ZMagnum »
From what I've heard and seen on dyno graphs the raised shift points don't help the 5.7L anyway. That's not to say we don't want this feature, we do, but I'm happy sticking with stock shift points at this time.
johan
Post by johan »
Yupp unless you have a cam in there you will probably have a loss in performance running the raised shift points.
Diablosport INC
08stonedcharger
Ok, what about the shift firmness function? When is that going to be available?
That is certainly available now...
ZMagnum
Post by ZMagnum »
I run raised shift firmness all the time and I have an 08. It's a 5.7L only option though. You can't do it on the SRT-8's since they are already running with raised shift firmness from the factory.
08stonedcharger
Hey Mike, It's fixed!!! I loaded an older software version(9r03) and then re-installed 9r04 and it works perfectly. Must have been a glitch when 9r04 was first installed.
Strange, but glad its working!
