Question
cameronmyers741149
Question
I have a 2014 Jeep GC srt, is tcm tuning supported on the 2014s or no? Or can someone check and see how f they have the file?
Re: Question
if it has a cal thats shared with 2015, yes. If not....no.
Post your info.xml file
cameronmyers741149
Re: Question
I called and talked to Diablo, they said it should have a tcm tune available. They are going to force an update. Great guys to work with!mikel wrote: Mon Jun 05, 2023 1:44 pm if it has a cal thats shared with 2015, yes. If not....no.
Re: Question
OK, did they verify the calibration ID?
cameronmyers741149
Re: Question
I’d who ever I talked to(his name was mike I believe) was able to see on the tool a cal id for the trans and said that there should be a tune available.
Re: Question
I just looked up your cal, and unfortunately i dont believe this will work, its not at all similar to the calibrations we support.
cameronmyers741149
Re: Question
So forcing the update isn’t going to do anything?
cameronmyers741149
Re: Question
mikel wrote: Mon Jun 05, 2023 4:16 pm I just looked up your cal, and unfortunately i dont believe this will work, its not at all similar to the calibrations we support.
Heres the info.xml file
Last edited by cameronmyers741149 on Tue Jun 06, 2023 10:00 am, edited 1 time in total.
Re: Question
unfortunately, no.
cameronmyers741149
Re: Question
Could you pm me or email me calibration ids you support for the 2014s? You think if I was to update the tcm with witech it make load a cal Id you guys support
Re: Question
any 15 cal is what we support, I dont have a way to say which 15 cals work in 14.
