Will disabling the speed limiter ony 2011 Silverado help with acceleration while I have the Diablo tune
This section of the forum is for discussion relating to the use of the T2 EX tuner/monitor on GM vehicles.
MIKEPLUG
Post by MIKEPLUG »
Will disabling the speed limiter on my 2011 Silverado 5.3 with my DIABLOSPORT Trinity EX2 platinum give me quicker acceleration with the 93 octane tune in
Re: Will disabling the speed limiter ony 2011 Silverado help with acceleration while I have the Diablo tune
No.... that has nothing to do with throttle response...
I can definitely get you hooked up with a custom tune for your truck... I've done thousands of those trucks over the years, including my own...
With the custom tune, you'll gain even better/quicker throttle response & acceleration, stronger/harder pull, smoother & quicker power delivery throughout the rpm's, better tranny performance/shifting, improved towing performance, etc...
I change a lot of things... a small sample of just SOME of the things are: disable the DOD/AFM, disable torque management, adjust part-throttle fueling/timing, WOT fueling/timing, knock retard settings, throttle settings, tranny torque, tranny torque management, tranny shifting settings (pressure/firmness, shift points, quickness), etc...
You can email me directly at: diablo DOT help AT gmail DOT com
-Lew
Return to “T2 for GM”
