Gear Ratio
Gear Ratio
I own a 2017 dodge charger 5.7 that had a 2.62 open diff and i swapped to a 3.09 limited slip. there is no option in the i3 tuner to change the gear ratio. also my service abs light is on and service traction control light is on and it won’t let me clear the codes.
Re: Gear Ratio
what is the code?
ZF8 should not need any changes for gear swap.
