My Trinity 2 will not update.
I received the tuner updated it just like I did with my intune i3 went out side hooked it up and it reads “there are control units in this vehicle that are currently not supported an update may be required. I go to update on PC or Wi-Fi it gives me a “unkown error” and a “fail log” I re installed the update driver on my computer same problems my is SN:201364536. Hope to hear back from you guys! Thanks in advanced!
Re: My Trinity 2 will not update.
can you post the info.xml file from the T2 drive here?
tech@diablosport.com
I don’t know what that file is can you talk me through on how to retrieve it please.
<tool_info platform="CERBERUS" sku="9345-D">
<registration sn="201364536" status="0" tool_oem="DIABLO" updates="0"/>
<applications count="5">
<application name="vehicle" rev="3r03z"/>
<application name="updater" rev="2r01v"/>
<application name="gui" rev="3r06o"/>
<application name="installer" rev="2r02g"/>
<application name="logger" rev="2r01o"/>
</applications>
<databases dbnames="2r01f" dtc="2r01a" vin="2r01r" SAE="3r01s" GaugeScreens="3r00e" GaugeLayouts="3r00d" Graphics="3t00ve">
<database mfr="DCX" tune="2t03by" pid="2t01ra"/>
<database mfr="FORD" pid="2r01o"/>
<database mfr="GM" pid="2r01n"/>
</databases>
<system rev="2r01b" config="3r01p">
<kernel release="4.11.12-rt16-diablo20" version="#4 PREEMPT RT Fri Feb 24 13:31:21 EST 2023"/>
<option name="Wifi" enabled="false"/>
</system>
<last-connected vin="2B3KA53H56H162801" mfr="DCX" ecus="2">
<ecu calid="05094779AE"/>
<ecu calid="04692392AD"/>
</last-connected>
<licenses available="1" tuned="0">
<option mfr="DCX"/>
<option config="CustomTuning"/>
<option config="FuelGas"/>
</licenses>
<GMUnlockLicenses available="0" used="0"/>
<unsupported calid="05094779AE" vin="2B3KA53H56H162801" oem="DCX"/>
<reg reg="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"/>
</tool_info>
</applications>
</databases>
</system>
</last-connected>
<option mfr="DCX"/>
</licenses>
</tool_info>
I see its asking for an update, is it not working for you?
Can you please attach the actual info.xml file here?
an unexcpected error has occured please wait while log is created. is what i get everytime i try to update through wifi or PC. and then after fail log is created it just sits on loading screen that says installing update wait.. and it will continue to stay like that for hrs.Till i uplug and go through the process again and ok i will paste that file on here.
"D:\info.xml"
OK, something is not happy, please give the team a call to get this sorted out, 561-908-0040hemichaser wrote: ↑Thu Jul 06, 2023 5:23 pm an unexcpected error has occured please wait while log is created. is what i get everytime i try to update through wifi or PC. and then after fail log is created it just sits on loading screen that says installing update wait.. and it will continue to stay like that for hrs.Till i uplug and go through the process again and ok i will paste that file on here.
Ok thank you for trying
when you say somthing is not happy what do you mean ? do you think i need to trade it out or somthing i thought this could be a simple fix just wondering .
likely a simple fix, through an update.
Ok sweet !
thank you for trying Hubspot partner agency
Mehendi designs
Mehendi designs
