Had some errors trying to change from 91 tune to diablo tune.
Kept getting stuck and a failed to set tire size while trying to go back to stock tune as well.
Device created a failure log but I didn't see it when connected to the dataviewer.
Issues while trying to change canned tunes.
Re: Issues while trying to change canned tunes.
try going into the quick adjust menu, and select 'restore all quick adjust' then try restoring the backup.
I will try that and report back, thanks!mikel wrote: Tue Jul 11, 2023 9:54 am try going into the quick adjust menu, and select 'restore all quick adjust' then try restoring the backup.
Worked like a charm!
,Thanks for the help, Mike.
Very much appreciated!!!!
glad to hear it.
