Trinity 2, Dataviewer and AEM Ugeo wideband
Posted: Thu Jul 27, 2023 12:36 pm
by Suivensports
Hi there,
I have 2019 Dodge Challenger Scat Pack with the Diablosport Trinity 2. Recently I installed the AEM Uego Wideband, and I added the new PID to the Trinity 2 with the right scaling so I have the same AFR value on the AEM gauge as well on my Trinity. My problem is I can not add the EAS AFR PID to the Dataviewer for data logging. Dataviewer shows the EAS tree but the chanel A analog signal there do not correspond with the scailing I have. Is there something else I need to do in order to have the right AFR PID added to the Dataviewer?
Re: Trinity 2, Dataviewer and AEM Ugeo wideband
Posted: Thu Jul 27, 2023 4:42 pm
can you please try this with DV2 and if it doesn't show, please attach the log file.
Posted: Fri Jul 28, 2023 8:15 am
by Suivensports
Good morning, I tried before with both, DV and DV2, at least DV recognize the EAS, but the DV2 does not, even after re-query at least twice, that is why I didn't logging using DV2. Attached you will find: the picture of the availables PIDs on DV2. A log using DV. A log using the Trinity 2 screen and the dashboard file I was using for the Trinity 2 HMI. I'm sorry, my be I'm wrong but I didn't see the point to do the log using DV2 if the PID wasn't there, please, pardon me if I wasn't right and let me know if you want the log anyway.
Posted: Fri Jul 28, 2023 9:27 am
Just to confirm, are you logging to the T2 and trying to play back on the PC, or trying to stream to the PC?
Posted: Fri Jul 28, 2023 9:50 am
by Suivensports
I'm trying to stream and log to the PC.
The T2 was just to show you that the EAS AFR is working.
Thank you for your help.
Posted: Fri Jul 28, 2023 11:09 am
by Suivensports
Does diablosport dataviewer has a windows operating system requirement?
Because I'm using Windows 10.
Posted: Fri Jul 28, 2023 3:45 pm
win10 is fine
Posted: Mon Jul 31, 2023 8:52 am
by Suivensports
Good mornig, Any idea on what can I do or try?
Posted: Mon Jul 31, 2023 11:47 am
OK, for now streaming the EAS devices is not supported, you'll want to record the logs to the device then play them back on a pc.
