2008 F 350 Throwing DPF CODE w/ V.9r02
Posted: Mon Aug 11, 2008 8:34 pm
by apex54321
I'm having a problem with a u7164 Predator tuner w/rev # V.9r02 causing "below or low level" DPF code, starts with check engine didn't get the code number. New 08 F350 Super Duty, 6.4L w/4200 miles and have added cold air intake and DPF back exhaust system. I'd like to find problem help???
RE: 2008 F 350 Throwing DPF CODE w/ V.9r02
Posted: Tue Aug 12, 2008 10:45 am
by cole
can your post your calibration id. Options/Troubleshooting/Show Calibration ID As well as posting the exact trouble codes from the predator.
Posted: Tue Aug 12, 2008 10:57 am
by apex54321
Hi Cole:
I didn't get the code but I did speak to some one in Diablo Sport Tec. support this morning. And he seemed to think it wasn't related to the Predator so, to better pin down the proble I'm going to operate the truck on the factory settings and see if the problem comes back. I'll le tyou guys know what happens.
Thanks!
Bruce
Posted: Tue Aug 12, 2008 10:40 pm
by VPO
If you have an AFE Stage 2 Air intake on the 6.4L, they are throwin a couple of codes. AFE still has not fixed it. I believe it is from too much hot air gettingin, as the Air-Raid & S&B air intakes dont throw any codes.
Posted: Wed Aug 13, 2008 8:51 am
by apex54321
VPO:
Thanks I have installed an air intake. Do you know if I Should go back to the factory until this is repaired.
Bruce
Posted: Thu Aug 21, 2008 1:48 am
by VPO
apex54321 wrote:VPO:
Bruce
It all depends if your dealer is "mod" friendly. Personally it doesnt take that long to change, so i would change it, just to prevent the from blaming IT.
Posted: Wed Sep 03, 2008 4:39 pm
by concoursd
Airaid has also confirmed that their intake will throw code P2002 DPF threshold error for newer 2008 calibrations. Early 2008 calibrations from Ford had a different threshold for that code and those early calibrations were used on the test trucks for these aftermarket intakes.
Posted: Thu Sep 04, 2008 2:19 pm
by cole
i spoke to marketing this morning and they are going to contact AirAid and AFE to get the problem child intakes so we can develop calibrations for those intakes.
