Hello, I've been using Intune3 for a while with 93 hemifever PCM and TCM 8spd trans tunes. I return to stock for dealer visit. Dealer did flash stock PCM and TCM with recall updates.
I went to install custom tunes back to truck, recieved error vehicle not supported. Went ahead and updated hand-held via wifi then install 93 hemi tune no problem. My issue is I do not see the TCM tune option under custom tunes in hand-held menus anymore. Please point me in the right direction.
Do I need to apply custom TCM tune to hand-held via computer program again? Or do I need a file modified from hemifever since my transmission stock tune was flashed by dealership?
Thanks.
Thanks.
2014 Ram 1500 5.7 TCM tune not showing a anymore
Re: 2014 Ram 1500 5.7 TCM tune not showing a anymore
please post the info.xml file.
Please see attached.
Thanks.
Thanks.
Hello Mike, did you have time to look at my file?
Thanks.
Thanks.
usually, if a dealer updates the ECM/TCM, then any previous custom tunes you had will not work, because now calibration ID's are different with the new dealer updates... You would need to just install the preset canned tunes, and then send fresh new copies of the tune files from the inTune to your custom tuner, and they would have to create you a new set of custom tune files to work with the new dealer updated ECM/TCM...
return to stock then give us a call and ask to force the tcm calibration update, then it should get back to showing the tcm tune.
Mike, so disregard your first reply about sending canned tunes hemifever. Since custom ecm tune is working after u updated handheld, just not tcm custom tune not showing on itune3 hand-held.
So I will return to stock tune and give you a call for tcm update. I take it I need to have iTunes hooked up to my house computer via dsdownloader when I call you correct?
Mike, thanks! Cynthia from your tech team took care of me. Forced tcm calibration fixed it.
Appreciate it.
Appreciate it.
