01 Mustang GT H-Pipe, CAI, Magnaflow catback W/Ocats smoking
string
Post by string »
01 Mustang GT H-Pipe, BBK CAI, Magnaflow catback W/O cats
a little bit of smoke when I rev.
using stock predator tune with the MIL disabled and the O2 sensor disabled also.
any suggestions about improving MPG or performance??
CALID: 'CVAF1B2'
VERSION: 7r50d (updated to 9r07)
107802
longalan2
RE: 01 Mustang GT H-Pipe, CAI, Magnaflow catback W/Ocats smo
Post by longalan2 »
you need to improve combustion. try the screamin deamon coils for one. next you might want to put in a set of ngk iridium plugs in it aswell. when you install the plugs you will want to index them. jacobs electronics sell the washers you will need to index them. the come in 3 different sizes and instructions on how to do it. just point the electrode to the center of the piston to give you better combustion. if you do these things i know you will feel a difference.
4648
Post by 4648 »
I'd suggest a good set of underdrive pulleys such as steeda's. not the piggyback style. coils are a waste of money. i'd be really reluctant to add washers to the sprark plugs to index them,as the 4.6 has a reputation of spitting out plugs as it is. if you data log the o2 sensors and the lambda correction with the predator and it's consistantly around 1, don't worry about a small puff of smoke when you crack the throttle. the o2s should be rapidly cycling between o and 1.00 volts in closed loop. if they are your fuel mixture is being controlled properly by the ecm. if you drive mainly in town, 3.73 gears might help fuel economy as well, without hurting highway mileage too much. If you're not getting any codes it's likely your fuel trim is fine. keep your tire pressures up, and drive like an old lady.
Silver 2001 GT Auto 14.106@98mph, 2.052 60ft
3.73 gears. predator program.
Then 13.731 @ 100.75 mph 2.020 60ft. Steeda UD, plenum spacer, ported plenum, Magnaflow CB. Street tires
New best, 13.415 @ 103.18. BBK x-pipe, and J-mod.
longalan2
Post by longalan2 »
try what you like, this combo has always worked for me. Good luck!
string
Post by string »
thanks for the reply, I'll try some data logging.
CALID: 'CVAF1B2'
107802
Return to “Predator Ford Gas”
