log upload??
log upload??
U7152
v.9r02
99 Ford F250 SD 5.4
I cannot upload saved live data to my pc,
dataviewer 3.1 connects til click " download log from tool"
Reported problem was ' command not supported'
any help would be appreciated. tks
v.9r02
99 Ford F250 SD 5.4
RE: log upload??
i couldnt load mine either,i had to load to the cmr dat200.then open up the data viewer,open the file logs in data viewer,then drag and drop that file into the dataviewer file logs.if that is the problem you are having.hope this helps
2001 f250 CCSB 4WD 5"Exhaust,
BallBuster Turbo,ITP Regulated Return,03 Headlights
CCV-MOD,,AIH Delete,Built-Trans,Programmer,DIY Intake,EBPV delete,Boost-fooler,Gauges,305's
RE: log upload??
ok, i'll give that a try....nope, won't download saved data from pred, connects & then starts communicating & just stops, no errors, nothing. something real simple i'm over looking..........tks
RE: log upload??
If I am not mistaken,I had to start the cmrdat200 before the predator upload or mine would also disconnect. I had both ready and waiting to go, then hit the pc side first and then log upload.It would show packets being counted shortly there after.
RE: log upload??
Yeah, the old CMR_DAT program and protocol are pretty finicky. egbertf, did you get it working with jbeasts suggestion?
johnc <at> diablosport.com
RE: log upload??
not yet,still won't download from pred. keep getting "command not supported" from data viewer. tried to connect straight to vehicle but no luck either.
egbert
RE: log upload??
did you log real time data? or did you select real time streaming?also,did you download the cmrdat200?if not you need to.you have to use the cmrdat200 to get the file from the predator..on the handheld, get yourself to the point where is says something about your xmodem being open or ready..dont start it yet.,,,go back to the cmrdat200click on download from predator..it should give you a file name bar to name your file.name the file.click open, once you have done this start the download process from your predator.this should work..as I just done this process myself about an hour ago.I hope this helps. (this process is for real time data logged.NOT real time streaming)
RE: log upload??
Yeah, try it with CMR_DAT_200. See the downloads page for your Predator.
RE: log upload??
i downloaded cmd_dat_200, can't find "xmodem open or ready" on the hand held. also, when i request download from pred, i don't get a open file- i get a save file? when i name file (f-250) click save cmddat200 shuts down,vista asks for permission to search for a solution on line & then it shuts down too, when i try to open that file i get a vista window " unable to create memory map for fixed file" . i logged real time data to pred while i was driving around, i can view the info on the pred but not the cmr dat 200.....thanks for tiring to help. is there a tree line for the pred? maybe that would help.......
egbert
RE: log upload??
upload update....wanted to make sure info was still on the pred & when i went to "log play back" all the data was not found. so i started to look for any files on my computer that had diablosport & found "masterpidlist on notepad. looks like all the info that was on the handheld. so now how do i get that info to cmrdat?
egbert
RE: log upload??
i am not sure what i was thinking..ive been loading way too many tunes i guess..not xmodem..im sorry..you have to go to the options/troubleshooting/log upload.do not upload yet..open cmr dat 200.click on get download from predator..then name the file but Dont click save or open yet...go back to the predator and now click on log upload,you should see sending bytes..now click the save name file in the cmrdat200.as for the file you found from the predator,u might be able to drag and drop in the cmrdat200..worth a try.
RE: log upload??
tried the drag and drop & cmrdat shut down as did vista windows... removed cmrdat and am now re-downloading cmr dat 200.
Progress, jbeasts10, got cmr dat 200 to download bytes, but only about 10%, I get a ford pod viewer warning window " More than 36 PIDS not supported" So now will have to change what??????
egbert
RE: log upload??
if you get home before 7:00 or can call the guys at diablo sport before then ,they should be able to get you going.I am at a loss by now.I am not trying to shut you out.I dont know at this point .Hope that you can call and get it straightened out.
