Great Job Brian
jbeasts10
Great Job Brian
Post by jbeasts10 »
That file woke it up out of the gate..feels like a fine tuned gas burner when you hit the pedal.Response is right on..if there is a way to add more fuel ,not sure how You adjust the curve for the fuel.When I say more fuel I mean from like 1700 rpm and up.Dont get me wrong,I am loving this tune but I havent seen any smoke..notta..just a lil more....pleaseeeeee..If you can.If you cant I will bump the pressure just a little.Great job and thanks.
sohfast94
RE: Great Job Brian
Post by sohfast94 »
Emailed. Thanks by the way.
:twisted:
Insert Clever comment here...
RE: Great Job Brian
Nice...
e08789
RE: Great Job Brian
Post by e08789 »
Brian, can more than one custom tune be installed at a time? The one that I had tried took away my ability to switch tunes. I need to be able to switch between towing and everyday driving tunes. I have 7r19dz back in right now, as this is what it defaulted too when I tried to install the 85street that you had sent. The 85 would show completed but when the tool tried to finish the install, it failed and I was back to the original crom.
sohfast94
RE: Great Job Brian
Post by sohfast94 »
I've figured out what needs to be done to get them to load. You'll have to send me a copy of your original backup. As for switching tunes that is not available. I can give you different tunes but you'll have to load and tune them seperatly for now.
