92 octane???
pubydingus
92 octane???
02 mustang gt... i havent ordered one yet but there is no option for 92 octane, right? thats the highest i can get in WA....
RE: 92 octane???
You can run the 91 octane tune or you can run the 93 octane tune with pulling 2 degrees out. I haven't seen any of the latest tunes from Kevin that are in the predator but the predator will allow you to pull spark out of any of the tunes. Your will be able to use the predator with 92 octane.
Cole Stevens
pubydingus
RE: 92 octane???
i also read something about o2 sensors i have no cats and my service engine light is on... can i disable the 02 sensors or what??? and also i read something about bbk cai? you can tune to your cai?
RE: 92 octane???
The Diablosport Predator has many CAI tunes inside of it. You can select for most of the Popular CAI intakes available on the market. I am unsure about if the o2 disable is still in the predator or not. But you can always get a custom tune to turn it off.
Cole Stevens
The U7146 has only 1 tune 93 octane performance tune. There are no CAI tunes.
There newest crom does not allow for any OBDII adjustments, disabling O2 or EGR delelte. A custom tune based of the newest crom for the U7146 is your best bet IMHO.
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
