im new here and im just wondering what features are you going to have with the programmer for the 09 ram 5.7.
msd turn off
intake option
idle adjustablity
air/fuel
spark/timing
shift points
shift firmness
gear ratio
tire size
will it be able to load custom tunes
what tunes will you have as far as performance tow and fuel economy
im just wondering what to look forward to.. i know S/C is working on the 09 ram also... but they wont give any information i just want to go with the tunner that does the most... you know
thanks never knew that about SC well theres one reason to lean to diablo id just like to know more about the options they are going to run on the new 09 ram.... thanks
Options should be very similar to the 08 Rams, WOT timing and fuel control, upshift/downshift adjustments, tire and gear ratio adjustments, MDS disable options, etc.
Mike Litsch DiabloSport Brand Manager Diablo Tech support by phone:
M-F 8:00 AM to 5:00 PM EST [email protected]
thanks is there anything that will be in the tuning for idle adjustment... i know since i put the intake and exhaust on it at idle it is a little low and rough at times... it was like that before but now it seems as if the rpms just sit a little too low... just wondering thanks for any help
just wondering if you had to guess a date to when this will be released to buy for the 09's what do you think. Also which hand held will it be for like the predator the trinity... also would you need anyone to test it out before you make it available to everyone? just wondering... thanks again
blazingzz wrote:thanks is there anything that will be in the tuning for idle adjustment... i know since i put the intake and exhaust on it at idle it is a little low and rough at times... it was like that before but now it seems as if the rpms just sit a little too low... just wondering thanks for any help
Idle speed will be adjustable.
o sorry did you still hear anything yet about which tuner it will be for or pricing? thanks again you been on top of everything we ask you I really appreciate it.... thanks
ok thanks... but like WhiteAries said have you gotten any numbers yet or having good luck with it? also do you do any 1/4 times just to see the difference on a stock truck and then with the performance tune? thanks for the info mikel
